Need help with starting
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Alright, I'm pretty sure it's the alt. but i thought I would ask here first b 4 i went out and bought one.
When I turn the key, all I get is a click, no starter just the clicking.
So is it the starter or alt?
thanks
thanks
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Have you tried the usual things? Check battery voltage. should be over 12 volts. check battery clamps, remove, clean, grease and replace. try jumper cables. The limited symtoms you state are classic dead battery. A bad alternator could be the cause of why the battery went dead but you have to start the car to tell for sure. A tip that I saw read in Popular Mechanics: A quick way to tell if an alternator is charging is to place a screwdriver at the back of the alternator on the rear bearing. If you detect a slight magnetism, the alternator is working. I tried it, it works. Another tip to tell if the alternator is bad: Jump start the car, remove the cables, if the alternator is bad, the battery will run down quickly and the engine will stop.
It's not my batt. checked that.
Now it could be the wiring. does anyone have a diagram?
i'll check the starter also.
92camaroJoe
Aug 13, 2015 06:07 AM
