Total Timing
Old Aug 20, 2003 | 01:12 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Total Timing
How do I know how much is too much or too little. Right now I run 10 initial, 32 mechanical advance and 48 total.
That seems like a lot....is it?
Old Aug 20, 2003 | 07:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You must be measuring in vacuum advance as well?
48 w/vacuum advance at cruise should be okay, long as it doesn't knock on acceleration. I've heard Mopars routinely run 50+*'s at cruise.
Generally SBC's take 36-38 all in by 3000...ofcourse there's several factors as well (gears, weight, engine,etc), but just as a guide line. Tis is WOT, no vac advance...i/e disconnect the vacuum advance and shott a dial back on it as you run the engine up.
But hey, if it don't ping, you're okay.
Old Aug 21, 2003 | 11:22 AM
Vader's Avatar
I've programmed some stock TPIs with 48° total advance without any problems. Of course, there is no vacuum advance and the system has to have a working knock sensor.
Old Aug 21, 2003 | 12:33 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Ya...its like 42 without the vaccum advance. The distributor has been recurved so that all of the advance comes in by 2200 or so.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
bellez77
Sep 5, 2015 08:39 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
