Cam and lifter question
Old Nov 2, 2000 | 10:13 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
My friend has a performer rpm cam with only 5000 miles on it. Question: can I reuse the lifters or should I get new ones? Everyone says it's the mileage that breaks in the lifters but I was told it is the initial 30 minutes at 2500 rpm that does it.
Also, is this cam too big? I run the stock center bolt heads. I plan to get a better intake at the same time.
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, Holley Street Dom intake.
Old Nov 2, 2000 | 11:33 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
There are different views of this subject, but here's how I always do it.
First, the only way I'd even consider reusing a set of lifters on a flat tappet cam is if each lifter can be placed back on the exact same lobe it had been running on. As a lifter runs, it mates to the its lobe and needs to always be placed on that same lobe.
I inspect the base of each lifter to see if there are any pits or signs of excessive wear. A straight edge, like found on a single edge razor blade, can be used to make sure that base isn't concave. Light swirl lines are okay though.
In order of least to most problems: (1) new lifters on a new cam, (2)used lifters replaced on the same lobe, (3)new lifters on a used cam, (4) used lifters on a used cam NOT on the same lobe as originally run. Some guys swap (1) and (2) in their priority listing.
Pits disqualify a lifter as does any that are concave on the base.
Roller lifters are a problem; they can be reused as long as they don't show any signs of excessive wear.
Hope this helps,
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Nov 3, 2000 | 09:32 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
I always opt for option #1. The only time I would consider option #2 is when "I" made sure every lifter came out of what position and I marked it. But I never use used flat tappet cams and lifters because they are so cheap.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Nov 3, 2000 | 09:45 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I too agree with changing the cam and lifters with a flat tappet cam. The only time I would do anything differently would be when I have a shot lifter and I am low on funds. Then I would JUST change the individual lifter. But, that has always turned out to be a short-term fix as the lifter seemed to wear badly and would need replacing in a relatively short time.
The only time I would consider re-using a cam and lifters is if I had to tear apart an engine and the cam and lifters had recently been swapped. Other than that, I can not think of a reason someone would go through all that time and effort to pull the cam and lifters and then re-use them again.
This is all for a flat tappet cam. Roller cam and lifters are reuseable if they don't have any unusual wear. I have yet to replace my roller cam, but I will tell you that when I dig into my TPI that far, the cam will be changed and most likely my 165,000 mile roller lifters. Again, I cannot see myself to go through effort with my TPI engine and then scrimping on a couple of hundred dollars by re-using my high mileage roller lifters. My time is worth more than the couple of hundred dollars I would save, especially if I had to go back into the engine again.
Do it right, do it once.
beastin91rs
Oct 9, 2015 07:38 AM
MoJoe
Sep 24, 2015 09:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
redmaroz
Aug 16, 2015 11:40 PM
