Stock 5.7 Heads vs L98 Stock Corvette Heads
I was curious about the differences between the two heads. I am working up a set of L98 heads. I do not know what the CC of these heads are. I figure the weight alone is worth something. Thanks, BranT
Bolt-ons and Nitrous
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
To my knowledge, the only difference between the two heads is the material they were made out of. They both come from the same casting I believe.
Black 88 GTA L98
DEAD
but a new crate engines on the way
E.T.F.A Member #11
Black 88 GTA L98
DEAD
E.T.F.A Member #11
Guest
Posts: n/a
The aluminum vette heads have 58cc combustion chambers (as opposed to 64) and a different D-port exhaust. The intakes are pretty much the same. The vette head does not have the heat riser/EGR passage in the head, on a corvette it gets exhaust gas for the EGR from the RH exhaust manifold. Something to consider if emissions are a concern.
