Measuring valve springs installed height...
Old Sep 9, 2003 | 09:22 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
What points do you use to measure valve spring installed height? The bottom of the spring to the bottom of the retainer? Or do you measure from the surface of the head (spring pocket) to the bottom of the retainer????
Thanks,
Paul
Old Sep 9, 2003 | 09:41 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The second one.
Then you add shims to gain the desired height if the one you measured is too much for what you want.
Old Sep 9, 2003 | 09:47 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Originally posted by AJ_92RS
The second one.
Ok, so........my suggested installed height is 1.750". That means I should end up with a measurement of 1.750" from the base of the valve spring to the bottom of the retainer?
Old Sep 9, 2003 | 10:23 PM
AJ_92RS's Avatar
Yea..... Measure from the spring pocket to the bottom of the retainer.
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
