Stroker 391 questions
I'm planning on building a stroker motor, but I need to find 6 inch
rods for a 2 inch rod journal. Pistons would also be helpful, It's a 3.75 stroke crank with the rod jounals ground down to 2 inches to give it a 3.832 stroke. Any help would be appreciated.
Car: 1991 Firebird
Engine: 383 stroker
Re: Stroker 391 questions
I've seen that done once in a magazine article. Very creative that's for sure..don't know if it's worth the hassle or not. But that's just my opinion.
Tom
Car: 87 Firebird Formula
Engine: 305 LG4
Car: 4
Engine: 6
Transmission: 5
Sounds like an awful lot of trouble and expense and whanot for a piddly 8 CID. Granted, CID is a good thing; but when you add up the incremental cost of doing that and divide by 8, I think you'll find that it's a whole lot cheaper to find a 400 block, and add about 20 real-world CIs over a 383 instead of just 8, without expensive and risky magazine-article tricks.
I found rods from C.A.T that will fit my requirement for the journal size. Does anyone know if I need to use a piston with a 1.00inch
compression height or 1.25? I'm thinking of going with JE since they have the widest variety I've seen so far.
Mickeyruder
Sep 2, 2015 02:45 PM
