converting maf to sd
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what do you need to convert a mass air flow tpi system to a speed density system?
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Following parts. Others may add to the list.
1. 870 ECM
2. MAP sensor
3. EGR
4. Harness mod at ECM from two plug to three plug.
5. Memcal
6. Various wiring, connectors, hose and plugs.
1. 870 ECM
2. MAP sensor
3. EGR
5. Memcal
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
