Big Idle problem
Old Oct 28, 2003 | 01:57 AM
killertransam89's Avatar
Big Idle problem
ok i just got an 86 t/a 305 tpi It has been messed with ALOT i just noticed that the a/c and air pump is missing with the egr stuff...will this cause my car to idle wierd? or is it the tps? to describe the problem when first starting the car when cold it idles so low that it dies....so i gotta hold the gas alittle for it not to die then after it warms up it idles up 1300 in park and about 750 when in drive .....any ideas??
Old Oct 28, 2003 | 06:06 AM
ede's Avatar
ede
scan it for codes, make sure the tune up is good and the tps adjusted correctly
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
