Edelbrock E-Tec head
Old Nov 6, 2003 | 12:09 AM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
I was thinking about going with the 170 aluminum E-Tec over the cast iron vortec heads.
Anybody have any experience with these heads the intake is 1.94 and exhaust is 1.55 so they should fit a 305.
According to the ad they out perform Vortec by 12hp and 11tq and flow 20% more on exhaust.
I will most likely put a Edelbrock RPM Air Gap vortec intake in. Other mods being done would be 3.42 gears, Sub frame connectors and srut tower, 4" cowl hood,MSD igntion and coil and cap.
Heres my car and mods
AIR FUEL
Edelbrock 600 cfm Electric Choke Carb, Edelbrock Performer Intake Manifold, 14" Open Air Cleaner, KN air filter
VALVE TRAIN
Comp Cams Roller Cam 260, Comp Cams Roller Lifter, GM Aluminum 1.5 Roller Rocker Arms, New Springs and Retainers, Double Roller Timing
EXHAUST
Edelbrock Headers and Y pipe, High Flow Cat, 3"Hooker Cat Back
DRIVETRAIN TRANS
Auburn POSI 2.73 gears, BM Megashifter(rachet)
COOLING
165 thermostat, Fan on at start, New water pump
ELECTRIC
New HEI Distributor, Computer Delete
DYNO
187hp 263tq rearwheel, 226hp 316tq flywheel
Old Nov 7, 2003 | 01:19 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Input please
Old Nov 7, 2003 | 05:50 PM
iroc22's Avatar
Can't say I've used them myself but from what I have seen, they are a superior engineered head. They have all the power making characteristics that a L31 head has, but they're not like a factory casting they have been carefully cleaned up. If you're prepared to do the work though, the L31 heads will be your best bang for the buck in this case; you're just adding a bit of weight with the iron casting over the aluminum. But sure if you have the money, the E-tec is a great head.
Old Nov 7, 2003 | 06:59 PM
85TransAm406's Avatar
Car: 1985 Trans Am
if you put them on your 305, you will lose compression going from a 58 cc head (stock 305) to a 64 cc (stock Vortec size). Or do they offer them in the smaller chamber size?
Old Nov 7, 2003 | 07:04 PM
StealthElephant's Avatar
Car: 87' Iroc
Get some AFR's at that price.....aren't those E-tecs real expensive? 1500$?
Old Nov 7, 2003 | 08:27 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
$1000 for the 170cc's
50 bucks more for the 200's
Old Nov 7, 2003 | 09:18 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
the ETEC are a little over a $1000 and the AFR are $1200-1500, plus the AFR won't fit a 305. If I get new pistons won't that raise my compresion back up.
Old Nov 7, 2003 | 11:12 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
new pistons, i wouldn't bother to do anything to the shortblock of that 305. the money its going to cost to rebuild the bottom end just isn't worth it. go get a 350 bottom end, and throw a set of E-tec 200's on there. you'll make way more power, way easier.
Old Nov 7, 2003 | 11:37 PM
Car: 1985 Trans Am
Never any subsitute for cubic inches! Except maybe cubic dollars...
Old Nov 12, 2003 | 01:19 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Would you all recommend the 170cc or the 200cc version for a street 350? I have 9.6:1 compression also. I'm looking for over 350 fwhp. I think either of the e-tec heads and a decent cam will get me over that mark. Plus Ill be saving some weight with the alluminum heads.
How much lift can a set of stock edelbrock E-TEC heads take? Im looking at getting a xe270 cam. or the xe268 roller cam. Both right around .500 lift with 1.5s.
I've been looking at heads for awhile and I think the e-tecs seem to be a real nice head.
Also do the e-tecs take centerbolt or perimeter valve covers?
Old Oct 6, 2004 | 03:37 PM
Chrome's Avatar
Car: 92' RS Camaro
Depends on what you want:
ETEC170 - dual plane, 220-230 duration at 0.050" and have a nice little torquey street engine.
ETEC200 - dual plane - maybe single plane - 240-250 duration at 0.050" high stall and good carb and you'll have a screaming motor (although better have the bottom end to keep up with it)
EDIT--------------------------------------------------------------------
Oh **** - rose from the dead - gotta love replying to searches - LOL
z28guy134
Sep 1, 2015 11:50 PM
italiano67
Aug 31, 2015 06:04 PM
earlpote
Aug 28, 2015 10:42 AM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
