Operating Temp.
Old Dec 18, 2000 | 09:00 PM
mikee2's Avatar
Operating Temp.
I have a 2000 Z w/all alum 5.7L. Book says it has a 180 thermostat but car allways runs 200-205. Is this normal. Car has aprox. 1400
miles.
Thanks M.J. Charbonneau
Old Dec 18, 2000 | 09:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds OK to me. Typically several thigns are true:
1. Temp gauges aren't very accurate.
2. Thermostats aren't very accurate either.
3. Thermostats are affected by pressure; usually the higher the system pressure, the higher their opening temp.
4. It doesn't matter whether you're looking at the LS1 (the one you have), LT1, L98, or whatever; or whether the block is aluminum, cast iron, titanium, chinesium, or even pure nonobtanium; the temp you describe is acceptable.
Enjoy the car! I'm sure it's a blast to drive.
Old Dec 18, 2000 | 09:12 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
My LS1 runs at the same temp. The only way you can get them to run cooler is to install a 160 stat and reprogram the fans with a HPP3.
Go to www.LS1.com a check out the "mods" section. They have a "fan mod" that is supposed to cool it down by making the fans turn on by a manual switch.
LS1 has a pretty good board in general.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 18, 2000 | 10:28 PM
matthew's Avatar
I wish my LG4 ran that hot. I finally got around to changing my therostat this weakend and now it runs at about 130. Before it would hardly get past 100.
Fanatic1074
Oct 3, 2022 05:57 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
Royal_Z
Sep 30, 2015 08:45 PM
ramicio
Sep 28, 2015 01:18 PM
Formula8r89
Sep 22, 2015 04:24 PM
