Porting Heads
Car: Red Rooster
Transmission: M5
Porting Heads
I am thinking of letting the pros port my heads.
Gasket matching, porting the intake and exhaust ports and doing some porting in the bowl area.
They will be putting in brank new HP valves(not sure on name) current intake valve size is 1.84 and they will be putting 1.94 intake. The exhaust valve size will stay the same.
They will shave the head a little, little bit to raise the comp by like .3 or .4.
They will put in a brand new LT1 springs, new oil seals, valve guides and 1.6 rockers.
My question is:
1. What kind of improvement will I be looking at in terms of HP and Torque?
Look below at my signature to get an idea.
2. Can I use non-alligning rockers?
3. Will I run into problems with the computer?
The car is running really strong for a 305. It took me few months to find a 5 spd in a superb shape.
I love racing with Mustangs and waiting for them at the next lights.
89Iroc,5spd,305 TPI,Flowtech Headers 1 1/2, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, Ported Plenum, Air Foil, MAF Screens and Fins removed, K&N, Gutted Air Boxes, Homemade AFPR @45 psi, Ram Air, TPS voltage changed, Throttle Body By-pass, Timing set @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac Shocks and lots more coming.
My question is:
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
See: http://www.isthq.com/~dan/ported.html
on how I ported my own 305 heads for my L69. Be sure that when the shop installs the 1.94 valves, that they relieve the combustion chamber around the valve or else you will experience less flow than even the 1.84 inch intake valve. Same goes with the bowl. It needs to be enlarged under the valve.
Also, be sure to post your E/T and MPH. "Really Strong" means nothing to me. My Saturn station wagon runs "Really Strong" too. So does my V8 Jeep Grand Cherokee.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
[This message has been edited by ws6transam (edited December 21, 2000).]
Daniel Burk
Transmission: 4L80E/4L80E
I couldn't answer your power increase question, but it should be noticable since it seems you've taken care of the typical induction and exhaust restrictions.
To add to what you mentioned, get screw-in rocker studs.
Or, rather than spend all that money on stock heads, get World 305 S/R's and have them pocket ported and gasket matched. It would be less money, and they'd work better. PHR mag did a comparison a few months ago (although the stock heads weren't maxed out, they were cleaned up and given a 3-angle job) - With just pocket ported S/R's, they picked up 50 hp on a 305 w/stock TPI.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
MoJoe
Sep 24, 2015 09:12 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
