CAM INSTALL QUESTIONS, !IMPORTANT!
Old Dec 23, 2000 | 02:26 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I'm swapping from a stock roller cam to a Comp Cams extreme energy 274. The specs are 230/236 .487/.490.
Will this cam be ok with my stock heads? Will the comp cams 981's work ok if I don't use 1.6 rockers? There has been lots of discussion over 1.25" springs having problems over .500" lift.
Also I read somewhere that when installing a flat tappet timing chain in a roller block there is clearance problems between the chain and the block. The block then needs to be grinded down slightly. Thanks.
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, Holley Street Dom intake.
Old Dec 23, 2000 | 02:44 PM
Jester's Avatar
Or..you could just use a roller cam timing set.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Dec 23, 2000 | 04:16 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
are you 100% sure they are interchangeable?
Old Dec 23, 2000 | 05:44 PM
ede's Avatar
ede
the bolt circle is differant on the roller and non roller timing gear.
ICON Motorsports
1st & 3rd
Old Dec 23, 2000 | 05:49 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Thanks Ede, one of my BIGGEST PETPEVS is when people give info they are not sure is true, at others expense.
Old Dec 23, 2000 | 06:47 PM
Jester's Avatar
Doh..I misread your post, and thought you were using a roller cam with a flat tappet timing set. Yeah, the bolt circle is different, as is the nose of the cam, but there are no clearance problems with the block when using a flat tappet timing set/cam. At least I didn't when I did that.
JSP Motorsports
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
