Tire presure in winter
Old Dec 7, 2003 | 05:58 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
I dont know where to post this ...
The car will be spending the winter outside..
and its parked in back.. the ground isnt flat so
I cant raise it on jack stands..
I read that you have to raise the psi in the tires
so they dont get deformed and such ..
how true is that theory ?
it was in an article about winterizing ur car ..
thx for any help.
Old Dec 7, 2003 | 09:25 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You can inflate the tires to 35 psi and move the vehicle forward or back every month to put a different portion of the tire on the ground.
One little trick I use is to get some 3/4" plywood cut at Lowe, Home depot, or other and park the car on four plywood sheets each being about 2'x2'.
Old Dec 8, 2003 | 05:28 PM
Spectre's Avatar
Engine: 3.0L/183
I see.. Ill just move it around a bit.. or store it
properly if the snow clears up ..
Old Dec 9, 2003 | 09:29 AM
Vader's Avatar
I usually go to 44 PSIG, but that's what my tires have as a maximum pressure rating.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
jrdturbo
Mar 31, 2016 02:58 PM
Formula8r89
Sep 22, 2015 04:24 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
