VE Calculator
Old Dec 9, 2003 | 04:50 PM
tt_g92_305tpi's Avatar
VE Calculator
How do I figure out the VE # for my firebird? Its a 91 305tpi 5spd.
Old Dec 9, 2003 | 07:01 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can take it somewhere that has a chasis dyno, or pull the motor and have it put on a real dyno. But in order to get a true reading, you'll have to use your entire exhaust system to.
Old Dec 9, 2003 | 07:49 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Volumetric efficiency = actual cfm / theoretical cfm x 100
Theoretical cfm = RPM x engine displacement / 3456.
Simply put: you need to know how much air your engine is consuming at various rpm's under WOT conditions to complete the equation.
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
fasteddi
Sep 2, 2015 10:29 AM
Grim Reaper
Feb 5, 2007 09:33 PM
