choosing intake manifold problems
Old Dec 27, 2003 | 04:49 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I decided I will be buying these heads
http://www.jegs.com/cgi-bin/ncommerc...68&prmenbr=361
But I cannot find an intake manifold with EGR that I can use.
I currently run the stock TBI setup on my camaro.
im looking for intake manifold up to 6500rpm.
most intake manifolds i do find say carburator. Can I bolt on my stock TBI instead?
also where is a good place to upgrade my TBI. i Dont want to go TPI and I'd rather not have to switch to carb.
(cali emmissions)
anyone know of such intake manifolds that's powerband goes idle-6500?(6000 also is fine) that has EGR and can use my stock or upgraded TBI? THANKS!
Old Dec 27, 2003 | 05:12 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I found this one
http://www.jegs.com/cgi-bin/ncommerc...04&prmenbr=361
but I cant tell if it has EGR, im sure it does though, since my 50 state legal heads works best with this says the description.
but will my stock TBI bolt on?
Old Dec 27, 2003 | 10:04 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Originally posted by TraviZ
I found this one
That intake is a good one but does not have a spot for EGR.
Get a TBI throttle body from a Big block truck and a TBI Four barrel adapter. Hood clearance will be an issue.
A Weiand #7525 (single plane) Team G or a Weiand
#8000 (dual plane) Action Plus would/should fit under the hood
with a TBI/4bbl adapter. both have EGR.
www.holley.com
Old Dec 27, 2003 | 01:01 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Look for a Holley manifold in the EFI section of Jegs called a pro-jection manifold. Your TBI will bolt up and fit an egr but you'll need a different egr valve.
or
get an edelbrock carb manifold and put a TBI adapter plate.
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
