Flywheel bolts, right or left handed???
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, I broke my 14mm socket already. So it makes me ponder whether these bolts are right or left handed.
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
The bolts are right handed and extremely tight. You have to hold the crank still. Also are you using 1/2" or 3/8" drive? You might want to try 1/2" with a breaker bar.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You might also try an SAE socket instead of a metric one...it'll fit better.
If you have access to one, an impact gun works well; if not, try a rubber hammer on the end of the ratchet handle to break them free.
Pete
Pete
Car: '87 IROCZ
Engine: 395 ZZ4
Thanks guys,
I found that the bolts take a 9/16" socket and are right handed. This car drives me nuts with a mix of SAE and metric nuts and bolts.
The way I broke the flywheel bolts free was to stick a bolt thru one of the TC holes in the flywheel and let that bind against the engine block in order to stop the flywheel from turning.
Now I can bolt the block to the engine stand.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
n easy way to tell the difference between sae bolts n metric is metric bolts have numbers on em for the grade of the bolt where as SAE bolts have lines..
84z96L31vortec
Aug 20, 2017 12:16 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
