NEED HELP QUICK PLEASE
Old Jan 13, 2001 | 11:10 AM
farm-kid/88camaro's Avatar
im going to look at an engine and would like to know how i can identify it as a 350 and tell if the heads are vortec's
it would be much appreciated
thanks
Old Jan 13, 2001 | 01:02 PM
Enkil's Avatar
This is very vague I know, so I'm sorry.. heh
Somewhere on the block there's numbers... these numbers will tell you if it's a 305 or 350. As for the vortec heads I'm not sure..
89 iroc-z 305 tbi
everything stock, except for a mirror that fell off
Old Jan 13, 2001 | 01:23 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Block numbers can be found at the back of the block between the top and second bell housing bolts on the drivers side.
Head casting numbers can be found under the valve cover. (you must remove the cover)
Get these numbers and go to www.mortec.com or post them here.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited January 13, 2001).]
Old Jan 14, 2001 | 01:27 PM
thanks for the info
I checked the head and block casting numbers and it shows them to be the vortec L31 heads and the Gen 1 crate motors 350 block. This is a crate engine and was made in 97. Does anyone have any info on this combination. It is a shortblock including oil pan, flywheel, vortec heads and the torsional damper. The valve covers are the standard black ones with center bolts. Im not sure if its 2 or 4 bolt mains, how would i check this?
Thanks, i hope someone knows something about this
Old Jan 15, 2001 | 05:36 AM
Pat Hall's Avatar
Unfortunately, the only way to be absolutely sure it's a four or two bolt main is to pull the oil pan and take a look. Most crate replacement engines are usually a four bolt, but not always. If you check the block casting number at mortec.com, some block casting #'s will be listed as being either two or four bolt, then some will be listed as strictly two bolt or four bolt mains. The block casting # is your best guess without pulling the oil pan.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 15, 2001 | 11:57 AM
thanks for the info, guess i'll take off the oil pan
thanks again
jon
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
