MAF or MAP
Old Jan 8, 2004 | 11:04 AM
88Z's Avatar
88Z
Car: 88 Iroc
MAF or MAP
I'm about to swap out the 305 from my Iroc to a 350 out of a 90 formula. I still have both ECM's but only the harness for my 305 with it's MAF system, which wouldn't work with the formula's speed density. what should i do?
Old Jan 8, 2004 | 05:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I coulda sworn for a 305 to a 350 swap, all you had to do was get the correct chip for the computer, and put larger injectors in.
Unless, that is, you -want- to switch over to speed density!
Oh and I guess you know this but you'd need a 350 MAF chip, you couldn't use the 350 SD chip from the extra computer you have.
Old Jan 8, 2004 | 06:07 PM
88Z's Avatar
88Z
Car: 88 Iroc
that's awesome. so all i have to do is pick up an 89 chip and i'll be set? and to think i was about start chopping up my harness for the SD!
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
