Estimates on Damage
Old Jan 9, 2004 | 04:15 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Estimates on Damage
Hi, need some estimates on damage. I believe the quarter panel and the fender are going to have to be replaced. If you guy would look and see what you think the damage would be, I have looked at hawks website and yearone, and I will probably purchase most from hawks provided they show good reviews (which I am searching for right now in another window.) Thanks. And if I put this in a wrong place moderator, please do what you wish, I just would like the have the luxury of people's opinions.
I am replacing the gfx from either some people I have e-mailed or hawks.
Old Jan 9, 2004 | 04:17 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
tailpipes. Will have them bent back if I cant afford hooker.
Old Jan 9, 2004 | 04:19 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
the fender, probably needs to be replaced.
Old Jan 9, 2004 | 04:20 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Last one, and the really bad one, the dent from the tree.
Old Jan 9, 2004 | 07:02 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
doesnt really look that bad to me. i'd just pull it back out and use a thin coat of body filler and prime it up and have it painted or paint it myself.....
Old Jan 9, 2004 | 07:42 PM
Morley's Avatar
Fender=$100 for new.
Ground effects ...maybe $50 from a junkyard
That last pic....Pull the back seat armrest and the plastic rear fender cover and you'll be able to get to that dent and start working it back out. Once you have it more or less back out flush, filler, sanding and paint..good as new.
Old Jan 9, 2004 | 08:09 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
IIRC, for the last one there is stamped sheet metal bracing that prevents access to it from behind. It may be easier to use a dent puller to get it back into shape.
Old Jan 9, 2004 | 08:12 PM
Car: 88 Camaro SC
Engine: SFI'd 350
If youve never done body work before youd probably leave that last one for the shop. Theyd probably be able to do a better job of getting it back into shape w/o lots of body filler and such.
Old Jan 10, 2004 | 11:44 AM
Morley's Avatar
Body spoon.
Old Jan 10, 2004 | 01:10 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
I believe I will leave it for the shop. My dad back when he was a mechanic, used to know this guy a lot so maybe I can get a discount. Maybe. . Exhaust is smashed in, sounds like it's choking. Oh well, they coming to look tuesday.
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
88CamZ
Oct 8, 2015 10:29 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
