L69: which pulleys does power steering belt attach to?
Just crank and power steering pulley? Or does it go over the water pump pulley as well. The only other accessory I have left is the alternator which goes on the crank, alternator, and water pump pulley.
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
The power steering pump pulley uses two belts. The groove at the back routes the belt to the crank and power steering pulleys only. The front groove routes the belt to the crank, power steering and A/C (if equipt, otherwise same as the back one).
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member:
SCCA, SCFB, SC3GFB
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member:
SCCA, SCFB, SC3GFB
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
evilstuie
04-14-2016 08:52 PM
Navy8125
08-22-2015 07:13 PM
