Need Help Fast!
Old Jan 17, 2004 | 02:01 AM
HaroGt14's Avatar
Need Help Fast!
Ok so this is going to sound really weird. In all the years I have been working on cars I have never heard of anything like this.
Ok so when I put my car into reverse it starts making the clicking noise like a spark plug is arching somewhere. But none of them are. So I give it a lil gas while on the brake and it starts going faster.
So I put the car in park and it stops, revving it up a little bit . . . nothing. So I put it in drive and bring the RPM's up a little and nothing. I don't get it. It doesn't do it under load from what I can hear (I have my dump open) but I think I can hear it sometimes. And the car isn't running rough at all . . .even when it does it!
Now I know it's not a rod or a wrist pin. And I don't think it's a loose rocker arm because a loose rocker arm would cause it to do it all the time. Not a spark plug because none of them are arching.
The only thing I can think of is maybe the torque convertor bolts came loose (I worked on a jeep that did that one time, and it had kind of the same symptons.) But I don't know. If anyone can give me some insight that would be great
Thanks,
Sean
Old Jan 17, 2004 | 02:14 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Does it sound like an exhaust leak?
If one of the motor mounts is worn, the eng may be moving enough to cause an exhaust leak, then re-seals when eng torque is removed/reversed.
If you have an engine driven cooling fan, maybe it's hitting something when the eng is torqued in rev gear.
Old Jan 17, 2004 | 02:38 AM
HaroGt14's Avatar
It's not an exhaust leak because it would be doing it all the time especially when you put load on the engine.
Also I have duel electirc fans. It's a 91 Z28.
Sean
I'm Stumped
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
