Engine Revs
Old Jan 27, 2004 | 02:10 PM
Frog's Avatar
Car: Z28
Engine: 5L injection
Transmission: Automatic
Engine Revs
Can anybody help?? Engine revolutions at cold approximately 1500 takes approximately 7 minutes to reduce to 750 revs, this is the same when the engine is hot. Has anybody any ideas how to reduce this time when the engine is hot. The car is a 1986 z28 5L injection automatic.
Old Jan 27, 2004 | 03:57 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Maybe you could check your coolant sensor and your air temp sensor?
Old Jan 27, 2004 | 04:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your throttle could be sticking or you could have a vacuum leak. It could also be your IAC and or TPS sensors. Many things to look at. I would check out how to data log and narrow down the problem before you start changing things.
Infested
May 22, 2018 11:56 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
db057
Aug 22, 2015 08:17 PM
perZ
Aug 21, 2015 05:51 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
