Brake lights?
Old Feb 1, 2001 | 02:36 PM
Blue92's Avatar
Brake lights?
Brake lights won't come on when pedal is pressed. All other lights work, what could be the problem?
Old Feb 1, 2001 | 03:03 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Sounds stupid, but check your fuses. If those are ok, check the brake light switch in front of the brake pedal to make sure it's operating properly, i.e., with multimeter on both terminals to see if you get continuity when the switch is actuated.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
