Is this tool big enough..??
Old Feb 20, 2004 | 05:56 PM
Cooter77's Avatar
Car: 89 IROC-Z / 11 2500 Sierra
Engine: 5.7 & Duramax
I am going to port my heads....
Is the NEW 4.5A "Advantage Rotary Saw" Big enough to do the job or do I need to spend more money for a Electric dye grinder..????????
Old Feb 20, 2004 | 09:18 PM
85TransAm406's Avatar
Car: 1985 Trans Am
That thing have a 1/4" collet? most tools for porting use that size. Electric die grinders go really fast, around 40,000 rpm, that's way to fast unless you can turn down the speed to around 12-13,000 RPM. I use an angled air die grinder, but have used a straight one just as well.
Old Feb 20, 2004 | 09:33 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here's how you can control the speed of an electric die grinder that doesn't have a speed setting.
Old Feb 20, 2004 | 09:45 PM
Car: 1985 Trans Am
Nifty...i've heard of that, and it was even recommended in my little "porting guide" that came with my standard abrasives kit. Good idea though. I personally like an air grinder as it's smaller and easier to control for me. I do kinda have little hands tho.
Old Feb 21, 2004 | 12:23 AM
Cooter77's Avatar
So this Dremel would work...
It does have a 1/4 inch collet.
It varies between 10k and 35k RPM's.
It also comes with a hand held tool for small carving and stuff.....
I just don't wanna burn it up. It did cost a couple bux.
And you know how those warranty people are...!!
Just didn't know if the thing had enough A$$ to pull a job like this.
Maybe if I paint a little bow tie on it......
:lala:
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Reid Fleming
Oct 10, 2015 09:56 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
