Headers
Old Feb 11, 2001 | 06:23 PM
Enkil's Avatar
Headers
I've got a 305 right now but someday I plan on upgrading to a 350.. My question is, can I buy a set of headers meant for a 350 and stick them on the 305? I don't want to have to end up paying for headers twice.
If I do this, what size headers/brand would you guys reccoment for a 350? I know there's a lot of variables in that.. but.. I don't know anything about it. heh
Also, I know headers can be too restrictive.. but could this be too.. unrestrictive, and cause similar negative effects?
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Feb 11, 2001 | 06:38 PM
ede's Avatar
ede
sure you can. they may not be the ideal header for your 305, and they might be the same p/n for a 305 or a 350.
ICON Motorsports
1st & 3rd
Old Feb 12, 2001 | 06:20 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
As always ede is right. The blocks are both the same, so the same headers will fit both. The only problem, if anything at all, would be you might have to advance your timing a little. But only if you get poping out of your exhuasts. Too little back presure. That way you won't burn up your valves. But if you have the stock muffeler, and cat, you've got nothing to worry about.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
