Does anyone know what could be the problem?
Old Mar 8, 2004 | 08:56 PM
RaMaiRGoD69's Avatar
Car: 88 GTA
The situation: I have 88 GTA w/ Lt1 Afr 195s port matched to the intake manifold 30 lb injectors comp xtreme energy cam 224 duration 535 intake 550 exhaust 1.6 to 1 roller rockers headman shortie headers K&N filter flowmaster american thunder exhaust 2400 stalll speed and a 3.70 rear gear
The datamaster I am using says that I am running 13.7 in the 1/4 mile. (I ran 13.7 before the cam cylinder heads and roller rockers were upgraded) Does this seem ridiculous? I was wanting to know what I might do to match my combo better maybe a 58mm throttle body instead of the stock one?
Old Mar 8, 2004 | 09:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What are your suspension mods? And what is this 'datamaster?'
Old Mar 8, 2004 | 10:21 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Datamaster is a logging program. I am confused w/ what you are saying you have. Is it an LT1 w/ AFR 195 heads? Or a Gen I 350 w/ AFR 195 heads, and a converted LT1 intake?
To me that setup should be running mid 12s possibly w/ some traction. I don't know that I trust the Datamaster program for "times."
Old Mar 8, 2004 | 11:47 PM
Car: 88 GTA
LT1
It is an LT1 out of a 93 Camaro. The LT1 has afr heads. I have the takeoff tires from SLP and all new bushings and i hav replaced my coil springs
Old Mar 8, 2004 | 11:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
No i know what a datamaster IS, i was getting at the same point as you....about trusting one for 1/4 mile times.
Old Mar 9, 2004 | 08:57 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Gotcha!!!
That motor in your car w/ AFR heads, and that cam should see 12s w/ the right gearing and converter. IMO...Maybe mid 12s...
Don't trust that Datamaster time stuff...
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
