Winterization
Old Mar 18, 2004 | 05:37 PM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
Winterization
Don't hurt me, but i left a carburated trans am sitting for about a year without any fuel stabilizer in it, what are the repurcusians i can excpect? what do i need to fix to get it to start again??
Old Mar 18, 2004 | 05:58 PM
dangerousd89's Avatar
Car: so many projects to little time
Engine: 350 tbi
depending on how much gas is in there i would drain the tank and get rid of the old gas first..then maybe change your fuel filter after running some new gas for a while...thats just me anyways
Old Mar 18, 2004 | 06:41 PM
Engine: 5.8Ltr 356
so it should start fine? cause it doesn't really. it started fine before.
Old Mar 18, 2004 | 06:46 PM
Engine: 350 tbi
depending on how bad the gas has gone it may cause backfires, rough idle and so on in my experiance... last time i had that situation i just dropped the tank and drained it in my 70 camaro but i had less than a 1/4 of a tank...
Old Mar 18, 2004 | 08:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If it doesn't have that much in it just add new gas to it and burn off the combined mix. It shouldn't be that bad after a year. I have let gas sit much longer without any problems.
Old Mar 18, 2004 | 11:18 PM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
storage&fuel
i have had my 91 camaro stored for a year with a full tank of gas will it be ok if i start it up with that gas or should i drain it and put fresh gas in it?is there anyway do drain the tank with it in the car?
Old Mar 18, 2004 | 11:21 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: storage&fuel
It should be fine. After you burn half of that tank add new stuff to blend it all together.
Old Mar 18, 2004 | 11:56 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Heck...when I bought my car it was sitting for 6 years with no fuel stabalizer. There was less than 1/4 a tank so I just added some gas to thin the mixture. But I still needed to change the fuel filter. Still ran real rough though.
Old Mar 19, 2004 | 12:09 AM
1fast91rs's Avatar
Car: 1991 RS
if i wanted to is there any way i can drain the tank with it still in the car?
Old Mar 19, 2004 | 12:12 PM
Vader's Avatar
Use the fuel pump or siphon it. Or, you could use an electric drill, hole saw, or match to empty your tank. Those wouldn't be my first choices, though.
If the fuel is only a year old, just add fresh, low octane fuel to mix with the older, less volatile fuel.
