Head Gasket Selection
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Engine Setup: 357cid w/AFR 195, Comp XE274, KB Flat-tops, RPM Air-Gap, 750 Speed Demon DP, Crane Gold RR
Deck Height: .045"
Combusion Chambers: 68cc
Valve Reliefs: 5cc ???
Bore: 4.040"
Stroke: 3.48"
Should I stay safe and go with a standard .040" composite head gasket which would give me a large quench area or is it OK to use a .015" steel shim gasket which would lower the quech area to something more optimal. I figure quench area is more important than CR, but I am not too sure about using a steel shim gasket with aluminum heads. I figure I'd be about 9.5:1 with an .040" and about 10.0:1 with an 0.015" gasket.
Deck Height: .045"
Bore: 4.040"
Stroke: 3.48"
Car: 4
Engine: 6
Transmission: 5
How do you know the deck height? Hopefully this short block isn't already assembled. But even if it is, it's not too late to do it right.
Deck the block. You'll never get the quench right with that much deck. But, the CR will be so low, the quench won't matter anyway. It's already lower than it should be with iron heads, let alone what it needs to be with aluminum ones.
CR is more important than quench. However, the need for quench is dependent on CR. As CR increases, so does the importance of "quench"; that is, at low CRs (less than 9¼:1 or so, which is where you are now) quench is insignificant, becaue the engine has no tendency to detonate anyway; but at 10½:1 or above, where your motor needs to be at the very lowest, it becomes far more important.
Deck to block to .000", run the 1010 .039", and mill a little off the heads to get the chambers down to 63-64cc. .020" - .025" ought to do it.
Car: 86 Trans Am
Engine: 406
I got the deck height from the engine builder. Yes, the short block is already assembled. I have used it before with factory castings am switching to AFRs in the next few weeks. The plan is to run this shortblock for a little while and then to move the top half of this engine onto a forget 383 or 406.
Car: 86 Trans Am
Engine: 406
What about these???
Vendor: Fel-Pro Performance Gasket
Product Line: Fel-Pro Performance Head Gaskets
Material: Steel Core Laminate
Head gaskets that seal.
Chevrolet: 262-350, steel shim, .015 in. compressed thickness, 4.100 in. gasket bore, 3.2 cc compressed volume, head gasket
* For use with cast iron or aluminum cylinder heads
http://store.summitracing.com/partde...art=FPP%2D1094
ambainb
Apr 25, 2016 09:21 PM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
