Help me! i have a engine belt problem
Old Mar 23, 2004 | 08:10 PM
Bammargera7152's Avatar
Car: 1982 camaro z28
Engine: 5.0 liter v8, cross fire injection
I just purchased a 82 camaro z28 and right now im unfimilar with the engine yet, and i noticed it was missing a couple belts. If anyone has belt layouts that would be a great help right now! until then im afraid of driving it because im unsure if one of the missing belts might hurt the engine. Thanks!!!!!
Old Mar 23, 2004 | 08:22 PM
jmd88iroc-z's Avatar
Car: '88 IROC-Z
Engine: 305 tpi
Transmission: 700r4/OD
THEY'RE PROBABLY AC, SMOG PUMP' OR POWER STEERING BELTS MISSING. IF YOUR CRANK, ALT., AND WATER PUMP BELTS ARE ON, YOU SHOULD BE ALRIGHT.
Old Mar 23, 2004 | 08:48 PM
Well i know the alternator is hooked up and the water pump it looks like one of the machines u hook to the belt is right underneath the alternator and the other one is on the top right side of the engine.
Old Mar 23, 2004 | 10:32 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Under the alternator is your smog pump.Right side top (veiwed from front)is your A/C compressor.Might hear some squeeling from belt slippage.Maybe a little popping from your smog pump not being connected.
Old Mar 24, 2004 | 10:46 AM
Thanks for the help. Im going to look at it again later tonight and maybe get a repair manuel to see the layout of the belts, It looked like the previous owner might have made a mistake with the belts but im not sure yet. If anyone knows how many total belts there should be that would be a help to. Also if anyone has any websites with belt layouts that would be a help to.
Old Mar 24, 2004 | 05:17 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I believe it 4 belts.One is smog to water pump pulley back to smog.2nd is Alt to water pump to crank pulley & back to alt.3rd is A/C comp to power steering to crank up to water pump & back to A/C.4th is power steering to crank & back to power str.Thats how i remember it anyway.
Old Mar 24, 2004 | 06:57 PM
Thanks ill try to take a look at it this weekend.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
