timing tab(?)
Car: 82z28
Engine: 406
Transmission: th350
timing tab(?)
The tab that the timing mark is Set/Read against is located where? I couldnt seem to find it. Maybe the belts where blocking my view but i just couldnt seem to locate it.
If the front of the engine was a clock where would it be located?
12 o'clock would be the very top/center
thanks for the help
82 with 0riginal LG4
thanks guys
thanks for the help
thanks guys
Transmission: 4L80E/4L80E
Try 12 o'clock.
You have to look between the back of the water pump and timing cover. Not sure about the '82, but I have to move this snake of vacuum hoses and purge canister control valve in order to look down there and see it.
The_Phoenix
Feb 4, 2016 07:10 AM
