Problem with starting
Old Mar 29, 2004 | 08:11 PM
Wookie768's Avatar
my car wont start
it sounds like it will turn over but wont when i turn it on for the radio everything turns on but i noticed the battery gauge is at 8
and i know i havnt started it in two days
does it need a jump or new battery
i know it will start if i do jump it but what would cause that to happen?
is somthing draining the battery when its off?
Old Mar 30, 2004 | 08:44 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
sounds like a dead cell in your battery. but also the alternator might not be charging the battery either.
Old Mar 31, 2004 | 01:34 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
You need to bring the battery voltage up to at least 12 volts with a battery charger or jump starting it and letting it run. Check your cables for corrosion and the battery acid level. Add distilled water to the battery if it needs it and clean the terminals with baking soda and water.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
