help needed if you can pls
first off i would like to say hi to you all
ok i have a 1991 rs camaro and live in rushden northants,ive had the car for 3 years now,and have spent a fortune getting it to the state its in now which is the mutts nuts imo
today just got it mot'd got it home,went to take it out for a quick blast and the damn thing wont start
the engine service light stays on,the engine turns but wont fire,and i can smell fuel,i tried to reset the ecm,by disconnecting the battery,but i still have the same problem,service engine light stays on and engine wont fire
if anyone can suggest a solution it would be much appreciated,or do you know of any business or mechanic that could come to me as i cant get the car to them?
thanks to anyone who replies
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Hi Surgeon,
I'm afraid injection is above me at the moment(dirty old carb until the 400ci turbo motor comes together)but you could ask the same question on the TECH/GENERAL ENGINE board.One of the things that board deals with is not starting.By the way what a lucky bugger living so close to the Pod.
350ci shortblock,headers,manifold,engine rebuild kit for sale!!!!
Car: 85 Z28
Engine: LG4 modified
Welcome aboard!
I trust you tried the usual stuff, like checking for a spark, and anything blocking the flow of air to the intake? I would be more inclined to say ignition, since you say it doesn't fire, which I presume to mean it cranks with absolutely no firing at all. If there was a spark AND fuel in the chamber, there would at least be a stumble.
Si
Si
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Since the engine service light comes on and stays on, it should have a trouble code stored in the computer. Have you tried pulling those codes yet, if so, what are they?
Zachattack0925
Aug 12, 2015 09:52 PM
