ENGINE LIGHT!!!!!!
Old Mar 2, 2001 | 04:38 PM
Blue5.71LE's Avatar
ENGINE LIGHT!!!!!!
hey guys i started up my car today and the idle is all outta wack. I had it out for a good run last week, and its been sitting since. I started it up and the engine light never went out, the rpms were bouncing all over between 4 & 10 after a couple minutes it reved up and the check engine light went out and it seemed fine.Untill i started it again and it did the same thing.TPS????????????????????
Old Mar 2, 2001 | 05:38 PM
HIX5000's Avatar
Did you check for codes?
Old Mar 2, 2001 | 05:59 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
you might want to check for IAC problems. if its only doing it when you start it, that may be a possibilty. i am not for sure if there is an actual IAC code that will set in the computer, but it may set of another one. hope this helps. also, does it do it when its just cold and you start it, or everytime you start it?
Wide Open Till You See God...Then Brake
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
