can i use a 85 gasket set for my 89
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
okay im bidding on a gasket set for a 305 tpi or tbi but i got a 89 tbi so i was hopeing that i could use the head gaskets and intakes gaskets and timming gasket or will they not fit on my car i know about the valve cover will fit cuz i got ho heads from 85.so basilcy what im asking is whats the differnece from 85 gasket set to the 89 beside the 2pc seal.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Some if the intake gaskets will work. Mainly the one for the intake base. The timing chain cover gasket should fit. The head gaskets should work also.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Sep 8, 2015 03:38 PM
NinjaNife
Aug 23, 2015 11:49 AM
