Do you guys experience this ?
When ever I break heavier than normal, my oil pressure drops to 0 for a couple seconds, and I hear the engine knocking pretty loudly. Is it because all the oil is shifting towards the front of the pan, leaving the oil pick up sucking air ? What can I do to prevent this ? Different design of oil pan ? Put more oil in it ? The oil is at the full level.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
92 Z28 5.7
Check out Truspeed
Car: 4
Engine: 6
Transmission: 5
That's exactly what it is.
The pickup may have fallen off your oil pump, which magnifies the problem. A better oil pan will help. How much oil is in the engine? Does this happen more when it's a quart low than it does when it's full? If so, try running it with an extra quart and see if that helps.
ICON Motorsports
ICON Motorsports
I'm afraid there's probably permanent damage to the bearing now since it knocks. Maybe not... It's a pain the *** to remove the oil pan with the block still in the car huh ! I never tried it, but I guess I'll have to remove the motor mounts, probably disconnect the transmission from its mount and jack up on the engine. Maybe I'll take this opportunity to fix my front seal leak too.. hehe
I put another quart of oil in it tonite and I'll see how it does tomorrow when I drive it.
I put another quart of oil in it tonite and I'll see how it does tomorrow when I drive it. If you try to remove the pan with the block in BE SURE TO WATCH THE DISTRIBUTER when your raising the block.I learned the hard way,you shouldn't have to unbolt the tranny from the block, but it is a bit*h.Good luck.
91'1LE Z28
K&N Filter (just getting started)All show no go.For now.
91'1LE Z28
theshackle
Sep 17, 2020 08:26 AM
