Difference between a Camaro and a Firebird?
Old Mar 7, 2001 | 11:18 PM
Jiffy's Avatar
I have this buddy....to put it simply hes a dumbass and he keeps telling me that my 92 camaro is nothing like a 92 firebird. He tells me that Firebird is too high end to be considered like Camaro. I told him they are practicly the same car with a different body and a few other changes like wheels and stuff. I know I am right. But could you guys tell him just so he gets the point.
By the way he drives a wannabe rice rocket !
[This message has been edited by Jiffy (edited March 07, 2001).]
Old Mar 7, 2001 | 11:21 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Body and interior.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 7, 2001 | 11:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just the styling differences. Mechanical parts are all interchangable and usually the same on both cars. Even differences from SS/RS/Z28/IROC etc are usually just options and basic styling.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 8, 2001 | 12:15 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
There is a difference with the TPI intake in those engines, and aerodynamics also.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Mar 8, 2001 | 12:30 AM
JPrevost's Avatar
Car: 91 Red Sled
TPI difference?! did we figure out if they had the same motor? I'm almost positive that the 91-92 TPI was the same on both the birds and the maros (speed density). Same with the v6, they're the same car. One thing I did notice was how the rear quarter panel molds into the roof, on the birds there is a more noticable "shelf" at door sill hieght, not sure if that was all birds or if I was comparing older style to new...?!?! Tell your "I_am_a_really_cool_guy" that they're both f-body's and there is no mechanical advantages. Tell him to find any kind of part that is for a bird ONLY, then show him that the same company makes it for the camaro. That should wize him up enough. If not I bet he's a punk that'll soon sell the car for a "pocket rocket."
, Jon (91 RS too many mods to list)
Old Mar 8, 2001 | 12:38 AM
MrJ's Avatar
MrJ
They are 95% the same car. The external difference is in the fender, rear quarter panels, hood, nose fascia, and rear fascia. the intake ducting on the MPFI and TPI Camaros and Firebirds are different as well. The interiors are different too. The suspensions are tuned slightly differently Other than that... same exact car in every way.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Mar 8, 2001 | 12:56 AM
Administrator
"The external difference is in the fender, rear quarter panels, hood, nose fascia, and rear fascia. the intake ducting on the MPFI and TPI Camaros and Firebirds are different as well. The interiors are different too. The suspensions are tuned slightly differently"
Correct.
Probably others too though.
Looking For:
87 IROC-Z 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited March 08, 2001).]
Old Mar 8, 2001 | 01:05 AM
Administrator
Wasn't there a difference in the air intake of the H.O. engines in like 84 because of the 2 different hoods on them also?
Looking For:
87 IROC-Z 350 TPI
Old Mar 8, 2001 | 01:24 AM
Administrator
Looking For:
87 IROC-Z 350 TPI
Old Mar 8, 2001 | 09:38 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually, when GM stopped putting the dual-snorkel intake in the Camaros (for MPFI/TPI), they used the same intake ducting as the Firebirds.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Frozer!!!
Jan 19, 2024 04:55 PM
I'llrocya
Feb 2, 2016 11:43 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
antares57
Aug 6, 2015 07:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
