Advanced valve timing
Old Mar 9, 2001 | 03:20 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I was wondering if anybody knew what the timing chain is set at from the factory on a 91 Z28 TPI 305?? I have read in many places that it was set 3 or 4* retarded from the factory and I'm going to put a new timing chain in while I'm changing the haed gaskets and want to ket a keyed set and advance it when I put the new one in..
anybody doing this ? Pros/cons??
Hecubus
http://www.tweak3d.net/temp/z28.jpg
Old Mar 9, 2001 | 08:46 AM
ede's Avatar
ede
i always thought it was straight up from the factory. if you advance it you'll increase torque and if you retard it you'll increase HP. straight up is a good middle ground between the two.
ICON Motorsports
1st & 3rd
Old Mar 9, 2001 | 03:20 PM
Polecat's Avatar
ede is dead on. Most cams now come out with at least 4 degrees of advance already ground in, so I always install dot to dot.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Mar 9, 2001 | 03:27 PM
gruveb's Avatar
Car: 1989 IROC-1
Everything I've ever done and read about cams is lining it up just as per the instructions and manual. In some vehicles, they have a washer/slotted cam gear bolt hole system that you can use which will advance/retard cam timing further than what was ground into the cam, but I don't know of anything like that for our cars....
You'd better match up the dots.
Old Mar 9, 2001 | 04:09 PM
355 IROC-Z's Avatar
advancing your timing will increase low end torque and retarding it increases upper end power, as previously stated. the proper way of doing this, from a performance standpoint, is to get your intake centerline and determine what you need from there. for just a general maintainence repair, just lining up the dots works just fine, depends what you are looking for
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
