engine building questions
Old Apr 21, 2004 | 03:25 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
well im looking at these pistions b/c they are the right compression ratiio ( i want with whats going to be ported l98 heads but the question i have is these are the type that have to be pressed to the rods and ive seen in catologs the other kind that have the floating pin and im not sure withc one is better or if it really maeks a differance. the blcok and internals i have now is a 87 350 tpi motor with 95 k on it. since i dont have alot of money i was thinking of have the stock rods reconditioned and using them. Im pretty set on what the rest of the motor is goign to look like so if someone could give a soem insight on this , it would be a great help...
Old Apr 22, 2004 | 04:30 AM
ede's Avatar
ede
nothing wrong with pressed pins, most engines have them. have some arp bolts pressed in the rods and have them resized and you should be fine.
Old Apr 22, 2004 | 08:13 AM
bbtaz97's Avatar
Car: 91 RS
excellant. i just wanted to make sure, thats what i was thinking but this is my first engine rebuild so i throught i woudl ask before buying them
thanks ede for your help..
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
