1 Injector has 17 OHMS, other 7 have 3 OHMS?
Old Apr 21, 2004 | 07:55 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
A friend lent me some un-used 30PPH Injectors because I was running out of injector.
After installing them, The engine missed on 3-4 cylinders. I Put the Old injectors back in Im on my way... But out of curiosity I tested the 30PPHer's, and 1 had 17 Ohms (normal) but 7 of the others had 3 OHMS... What is the DEAL here?
Old Apr 22, 2004 | 08:51 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Just found out that the 1 injector that is reading normal is a different P/N than the others.
Old Apr 22, 2004 | 01:53 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Sounds like either the other 7 are bad or simply low impedance injectors meant to be used with an aftermarket ECM, like DFI or Commander 950....
I would check the part # with the manufacturer and find out...
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
