tired of burnt plug wires
any sleeves or anything i can buy to slide over boots that can take the heat
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
The first thing to do is to get the wires routed away from the headers. You need plug wires with all 90* boots. You CAN get boots for wires too though if you have no otehr choice. I bought a set when I got my MSD Superconductors, but the boots were too big to slip them on. Even without any other protection, good routing has kept my wires from being burned for about a year now.
Car: 1989 IROC-1
My 84 L69 has some of those brackets mounted to the engine block below the heads. Only way to get to them is from under the car, but they definately don't burn up. Even if you don't have the brackets down there, you could probably rig up a little super glue and a magnet on the back of one of those plastic plug wire retainers to hold them away from the exhaust. Just a thought.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
