Starting problems !!!
Old Mar 18, 2001 | 10:30 AM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
Transmission: 6 Speed
Everytime I try starting my car, it sounds like something is loose and then the car turns over. Then sometimes the car just doesn't start at all. I wait there trying it, you can hear a clicking sound but that is it. If I leave it for a little bit, and try again, 7 out of 10 times it will start then. What could this be ???
Thanks guys/gals
John
Old Mar 18, 2001 | 10:38 AM
jms's Avatar
jms
Sounds as if your starter may be loose. Have someone crank the car while you look at the starter. It could be "jumping" around. It could also be a loose starter solenoid or loose connections at the solenoid.
However, I would guess the bolts are backing out that hold the starter to the block or the aluminum end on the starter has cracked or broke completely.
Another possibility is a cracked flywheel but I have seen several "broken" starters.
jms
Old Mar 18, 2001 | 09:36 PM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
Ok thanks for your input JMS, I was playing with the starter today and noticed that the solenoid was a little loose. I was actually able to wiggle it slighty. I hope that is the problem.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
