Distributor Clamp Down Bolt...What tool do you use?
I can't seem to get to this thing no matter how hard I try... I can read it at about 4 degrees ATDC...which is not good. Don't understand why it is running as good as it does with the timing that far off.
Gunmetal 89GTA T-Tops L98
700R4 with 3.27 gears, street tires
Best 60 ft: 1.996
Best 1/8th mile: 9.02 @ 76.5mph with 60' time of 2.14
Mods: air filter, hypertech chip, 3" exhaust (no cat.)
Current Mods: 8.8wires, cap, rotor, +4 plugs, MAF screens, Servo, custom Ram Air, TPIS air foil, and some tuning
Going to the track this weekend...hopeful for improvements.
Best 60 ft: 1.996
Car: 04 GTO
Transmission: M12 T56
Yup, plunk down for a dist. wrench. And heres a tip from a guy who just set TPI timing for the first time theother day...take the vacuum lines off the EGR solenoid and the wrench will fit between theports so you have a real range to turn through.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
Car: 89 Formula T-Top
Engine: 388 MiniramII
The distributor wrench sold at Sears is the best for these cars I think. It fits perfect. The size is 9/16 and costs like $9.
'89 Formula 383 TPI
'89 Formula 383 TPI
Spend the money for the dist. wrench. Also remove the two 10 mm or 3/8 bolts that hold the coil and the vac. switch to the bracket on the intake. Thats the simplest way, it takes an extra 2 min if that.
87 LB9 5spd 3:42 rear T/A flame red
every free
3 inch flowmaster / tes
ported intake
msd ign.
B&M ripper & centerforce
every free
ported intake
msd ign.
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I found that the dist wrench interfered with the rear of the TPI lower intake manifold, but the 9/16 crow's foot was a perfect fit.
89 IROC with lots o' stuff
there are two kinds of distributor renchs i buy, the ones from snap-on that cost 40 dollars each and fit the application they were made for. the other is the cheap universal wrench from sear that i heat with a torch and bend where i need to get it to fit. if you have a torch the second is way cheaper.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Get a dist wrench, get a cheap Chinese one from the local parts shop. They will normally interfre because the bottom length. I heated mine for 5 minutes with a propane torch and added another L bend about 1 inch from the opening. just another idea
The Auto Zone one that comes with the 9/16 and 1/2 works great.
Livin the hot rod dream, one day at a time.
lg4
slp muffler
pro flow air cleaner
performer intake
more to come
lg4
slp muffler
performer intake
more to come
In my 84 Firebird w/v6 I bought a distributor wrench, but it didn't fit. The 9/16 was too small. So I used a 15mm socket 1/4 inch drive with a swivel extension in it. That was the only thing I could get to work on it. But then again, every time someone says to use this certain size, it's always something different. My car is weird like that.
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
Damon
Sep 26, 2015 04:29 PM
