would this be the coolant temp sensor?
From: First one out of liberty city, burn it to the ground
i was watching shadetree mechanic today, and they brought up a point when changing the coolant temperature sensor. Since the sensor tells the computer if your engine is cold and when its cold it dumps more fuel, then if it was bad it would run rich 24/7. My car does, it constantly runs rich and gets crappy gas mileage...could this be a reason for the problem?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
1989 Firebird
btt
1989 Firebird
1989 Firebird
o2 sensor was replaced and it still does it...
1989 Firebird
1989 Firebird
This sensor is pretty easy to test, I checked mine last week. You need an ohmeter.
http://www.racer-x.f2s.com/proc/ctslearn.htm
The table at the bottom of that page gives the approximate readings you should see if the sensor is good. As the car cools down, you can actually watch the ohmeter reading going up (if you've got a good digital meter).
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
