Just How Critical Is adjusting your TPS??
Old Mar 25, 2001 | 06:10 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Just your thoughts or coments or expierences??
Hecubus
http://www.tweak3d.net/temp/z28.jpg
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel & Oil Press Guage's
Old Mar 25, 2001 | 06:48 PM
shawn87gta's Avatar
The TPS is what tells the ECM how much "gas" you're giving it, when it's at idle, partial or wid-open throttle. Idle setting should be in the .54v - .58v area, and wide-open should send 4.75V or higher. You should be able to actuate the throttle thru its entire range and not see any spikes or drops in the voltage - it should increment smoothly. It's the accelerator "wire" in the fly-by-wire analogy.
Old Mar 25, 2001 | 08:53 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
So if it spikes at all while opening it up then the sensor is possibly bad??
Hecubus
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Mar 25, 2001 | 11:22 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
When you check a TPS, the best thing to use is an analog volt meter. That way you can watch the needle go up, and it'll be really obvious if there are any spikes or drops in the voltage. This is one of the only times that a analog is better than a digital meter. And yeah, if there are any sudden spikes or drops, your sensor is most likely shot.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
