Timing Problems
Old May 23, 2004 | 02:41 PM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
Timing Problems
I just rebuilt my distributor with a new cap, rotor, coil, ignition module, and everything is installed correctly. I have no timing marks at all to follow, so I had to put a scredriver in the chamber and feel when the piston came up and hit it. So after getting to my so called TDC, I lined the rotor up with #1 cylinder and put the cap on hooked everything up, and it wont fire at all.
Could the fact that I dont have any timing marks at all cause me to be completely missing. I figure I'd at least be close, getting the cylinder almost to TDC. Maybe I'm missing something here. Does anyone know how I can get the timing closer without having any marks? Any info would be greatly appreciated, cause I gotta get this thing to work tommorow morning. Thanks.
Old May 23, 2004 | 03:32 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Using your metod you could still have the timing off. Remember the piston hits tdc on two strokes compression and exhaust.
Just add one step to what youve done so far. With the spark plug out plug the hole with your finger and tap the engine over with the starter. When you have air coming out of the hole your on the right stroke. Then line up the marks you made using the screwdriver method and youll have tdc #1 compression. That should get you close enuf to get her started.
Old May 23, 2004 | 05:34 PM
ede's Avatar
ede
yep the piston is at TDC twice per cycle. have someone crank the engine over and hold your finger or thub on the spark plug hole untill you feel the compression, that would be the TDC you want.
Old May 23, 2004 | 09:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Try flipping the rotor 180° from where it is now. Just a thought.
Old May 24, 2004 | 04:36 AM
ede's Avatar
ede
you can't flip it, it's indexed to one position
Old May 24, 2004 | 08:52 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Are you sure you don't have any timing tabs. They are really hard to see and get funk on them over time which makes them even harfer to see. Look down behind the water pump. Unless your timing cover has been tmapered with or you have a serious amount of corrocion goin on down there, the tab should be there.
Old May 24, 2004 | 12:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
When my timing was 180 off, i just loosened the distrubutor hold down clamp, raised the distributor from the oil pump and cam gear, rotated the rotor 180 from where it was and it fired up...but hey, what do i know.
Old May 24, 2004 | 01:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am pretty sure he meant pulling the rotor off and turning it around while the base stayed put.
Old May 24, 2004 | 01:53 PM
ede's Avatar
ede
what you did isn't what you said or what you meant isn't what you said.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
