Is 39 knock counts alot..
Old Mar 29, 2001 | 01:46 PM
kream-'s Avatar
How about timing at 35 degrees around 2000rpm cruising..
Also at WOT, the Air/fuel ratio got to 10.7:1
This is for TPI S10....
Old Mar 29, 2001 | 02:42 PM
theformula's Avatar
that seems like a lot to me. With my blower, the most I've recorded is like 11 knock sensor counts at WOT. What about your knock retard? What are the readings on that?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 29, 2001 | 07:50 PM
kream-'s Avatar
zero
Old Mar 29, 2001 | 09:37 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You are only giving us a "snap shot". The more important stat is the amount of knock retard encounters WHILE you are encountering these "knock counts".
39 knock counts all at a couple degrees is a lot better than 12* of knock retard with only 10 knock counts.
Ignore the knock counts and look at your knock retard AS it is happening. Don't just look at the "final tally"; the knocking has already occurred. You need to "play it back" and check the amount of retard you encountered when these knock counts were happening.
[This message has been edited by Glenn91L98GTA (edited March 29, 2001).]
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
