engine problem
Old Jun 6, 2004 | 11:17 PM
cross_fire3's Avatar
Car: 83 camaro z28 cross_fire
engine problem
my engine turns over but it won't start. i took out one spark plug(the front right if your looking at it from the front of the car) to see if i had a spark, i turned the engine over and it didn't create a spark but the engine started. but when i put the plug back in the engine wouldn't start anymore. could some one please explain whats goin on?
thanks
Old Jun 7, 2004 | 10:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Moved: This should help you better.
Old Jun 7, 2004 | 10:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Let me see if i understand this correctly:
Your engine turns over but doesn't catch. You have narrowed it down to no spark. You pull the #1 plug (thats the plug on the driver side, closest to the front) to visually verify the no-spark condition. You turn the engine over and you get no spark through the #1, but the rest obviously spark as the engine catches. Upon placing the plug back into the hole, it continues its no-start condition.
That's how i am reading it. How are you testing the spark? Have you checked the other 7 plugs?
Just a WAG, but whens the last time the ignition module was tested/replaced? That has a tendency to just go "bad" without any warning. They can commonly act like that "no start, then it starts for a bit, then it doesnt start."
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
