Is it safe to run the car with JUST shorties (for a brief period of time)
Old Apr 2, 2001 | 09:44 PM
RoadRocket L98's Avatar
My question is
Since Im installing my headers and y-pipe in my garage, I need to know if this procedure is safe. I first plan to install the headers themselves (Hooker SuperComp shorties), then I plan on running the engine (with just the headers) just long enough to back it up and drive up on my ramps to install the ypipe. Does this sound safe or are there some concerns about running on just the shorties? Any help is appreciated. Thanks!
'83 Firebird 2.8
'89 Firebird Formula 350
2nd owner, red/grey, t-tops, dual cats, and a 3.27:1 rear
K&N, TB bypass, No MAF screens, CAI, full Accel ignition
Old Apr 2, 2001 | 09:52 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
It shouldnt hurt anything for that short period of time. The problem is you have no backpressure like that. Just don't rev the engine up much.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Apr 2, 2001 | 09:55 PM
ede's Avatar
ede
you should be ok, but make sure they aren't aimed at a fuel line, or anything else you wouldn't want getting cooked
ICON Motorsports
1st & 3rd
Old Apr 2, 2001 | 10:40 PM
KW87GTA's Avatar
I've done this install and it's a pain in the butt. You will probably have to get under the car anyway, to get at some of those tough to reach botlts so it might not hurt to put it on the ramps first, they can't be so high that you can't work on it. I wouldn't worry about moving it though, like mentioned above, as long as they don't come off near anything that can get damaged from the heat. And actually I ran my car out of the y pipe once and turned the best times ever, see sig, and felt bad to put the tubes on lol. The only downside was that this thing sounded like 10 Harleys parked in my ear, and the floor boards were actually vibrating to the eye. Well so it goes, good luck.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Apr 3, 2001 | 06:17 AM
Macgyver's Avatar
I just put the car on jackstands when it was time for the Y-pipe, you'll need all the room you can get.
Old Apr 3, 2001 | 12:25 PM
Superblue87Formula's Avatar
I took my car for about a 20 mile drive to the exhaust shop after putting on my headman shorties, didn't have any problems. One thing though, those mugs will be hot even from just backing up. Also make sure there are no flammable chemicals (oil, fuel, etc) spilled under your car because flames are going to shoot out of your headers.
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kyleb24
Aug 15, 2015 08:24 AM
BlackBoulder
Aug 11, 2015 11:15 PM
