406 heads on a budget
Old Jun 13, 2004 | 06:44 PM
j0n's Avatar
j0n
Car: 1999 Corvette
Axle/Gears: stock dif/3.42s
ok i'm swapping a small block 406 into my originally L03 formula and after the neccesary rear end and trans building, exhaust, and cooling upgrades that doesnt leave me much room to modify the 406 but i dont want to run the rebuilt 882 heads that are on the car...granted i could get better springs and a big cam but from what i've heard the 882 heads flow like sh*t no matter what so back to the question...i need decent heads for a .510-.520 duration cam for a decent price...im not going for an all out drag car but i want some decent flowing heads...any ideas? id like to spend around 500 bucks or less
Old Jun 13, 2004 | 09:50 PM
j0n's Avatar
j0n
Car: 1999 Corvette
ttt
Old Jun 13, 2004 | 10:39 PM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Competition proucts / Pro topline Vortec heads.
These heads will out flow your smog 882s and the springs are good for up to .510" lift.
Old Jun 13, 2004 | 11:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Agreed go with Aftermarket heads. THe PRO vortecs are performance vortecs out of the box, far superior to the GM vortec IMHO.
Old Jun 14, 2004 | 12:43 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
if they are going on a 400 based block, i believe they need steam holes drilled. Not that thats hard, but just something to look at.
Old Jun 14, 2004 | 02:58 PM
j0n's Avatar
j0n
Car: 1999 Corvette
how would one go about getting steam holes drilled?
Old Jun 14, 2004 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pick up drill.
Put bit in drill.
Turn head upside down.
I think you get the picture.
It's 6 3/16" or so holes (size is absolutely not critical) drilled through the deck. Use a head gasket as a template and mark them with a center punch.
So easy I can even so it, usually without screwing anything up much.
{edit} That's 6 holes per head. Sorry if I made it sound too easy.
Old Jun 14, 2004 | 03:57 PM
j0n's Avatar
j0n
Car: 1999 Corvette
Originally posted by RB83L69
Pick up drill.
Put bit in drill.
oh ok...sh*t even i can do that...now i gotta find a vortec intake....helllllllllllllo ebay
Old Jun 20, 2004 | 10:12 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Watch your compression with the 64cc chambers and the bigger 400sbc bore. With 4 valve relief flattops 10.5 would be easy and not good for a cast iron head. Dish pistons would be ok though. Going through the same thing now
C409
Sep 23, 2015 04:30 PM
gta90
Sep 15, 2015 04:00 PM
mddaniel
Sep 8, 2015 05:16 PM
camaro71633
Sep 1, 2015 10:24 AM
