MPFI
MPFI
i JUST did a test, I noticed that I was only getting 8 miles per gallon.(spark plugs changed to new, O2 sesor changed to new,filter changed) the engine sounds like its mifiring(shaking at Idle) what are the possibilities of low mpg???
3.1,
Check spark plugs, wires, distributor cap and rotor, coil resistance, ignition timing, vacuum leaks (including the PCV and brake booster), a internally leaky EGR valve, MAP sensor, CTS sensor readings.
One of these should get you close to the problem. Do you have the MAP/SD MPFI? (What year?)
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Later,
Vader
Car: 1986 Firebird
Engine: 2.8 V6
Speed density... I agree, sounds like it's time for a major tuneup!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Springster
Sep 13, 2015 01:38 PM
87_Camaro
Oct 4, 2001 01:31 PM
